The GL-15 Evictor is one of the more unusual primary weapons coming to Helldivers 2, and it could change how players build their loadouts. Unlike a traditional support grenade launcher, the Evictor takes the primary weapon slot. That means players can keep a powerful anti-tank support weapon while still carrying a weapon built around explosive damage. For players who regularly manage different Helldivers 2 Items during missions, this could make the new weapon particularly interesting.
The Evictor is scheduled to arrive with the Ironclad Democracy Warbond on September 22, 2026. It uses a pump-action design and manually reloads one round at a time. Its expected role is not long-range precision shooting, but rather medium-penetration explosive damage. That gives it several possible uses, especially when players need to clear groups, destroy structures, or control narrow areas.
A Different Kind of Primary Weapon
Most primary weapons are designed around direct combat with ordinary enemies. The Evictor takes a different approach by bringing explosive utility into a slot that normally belongs to rifles, shotguns, or similar weapons.
That distinction matters because players usually have to sacrifice something when they want extra explosive capability. A support grenade launcher takes up the support slot, while other explosive options can occupy the secondary weapon or grenade slot. The Evictor could reduce that pressure.
This means a player can potentially use the primary slot for structures and crowd control while reserving the support slot for threats that demand heavier firepower.
Clearing Bug Holes From Safer Positions
Terminid missions could be one of the clearest places for the Evictor to shine. Closing Bug Holes from a distance gives players a useful way to deal with nests without immediately entering the middle of a swarm.
This could be especially helpful around larger nests where several enemies are already moving toward the squad. Instead of using a valuable stratagem or pushing forward with a short-range weapon, players may be able to fire explosive rounds while maintaining some distance.
The weapon should also benefit players who like controlling the battlefield before moving in. Clearing an objective first can reduce the pressure when the squad eventually advances.
Useful Against Automaton Positions
Automaton outposts could provide another strong use case. Fabricators are often positioned around groups of enemies, making direct attacks more complicated than simply shooting individual targets.
The Evictor is expected to offer another way to approach these objectives. If players can place shots correctly around Fabricator vents, they may be able to destroy structures without relying on a separate explosive tool.
That could make the weapon attractive during missions where players want to keep their support weapon available for heavier targets.
Making Room for Specialized Equipment
One of the biggest advantages of the Evictor may be what it allows players to bring rather than what it does by itself.
A player could potentially pair it with a dedicated anti-tank support weapon and use the two weapons for very different jobs. The Evictor could handle structures and groups, while the support weapon remains available for heavily armored targets.
Grenade selection could also become more flexible. Players who normally bring an explosive grenade for structural utility could instead consider Stun, Smoke, or Thermite depending on the mission.
This creates more room for specialized builds without completely giving up explosive utility.
Managing the Reload
The Evictor's manual single-round reload is also its biggest tactical concern. Players cannot simply empty the weapon and immediately continue firing at full speed. Every shot needs to be followed by another loading action.
That becomes dangerous when Hunters, Berserkers, or other melee enemies close the distance. A player who starts reloading at the wrong time could quickly lose control of the fight.
For that reason, the Evictor should reward players who maintain good positioning. It is likely to work better when used from behind cover, around corners, or at a comfortable distance rather than directly in the middle of a swarm.
Making Every Shot Count
The expected limited ammunition capacity adds another layer to the weapon. Early information has pointed toward roughly 30 to 50 total rounds, although the final numbers should be confirmed when the weapon launches.
If that ammunition limit remains, players will need to think about what deserves an explosive shot. Groups, structures, and medium threats are much better targets than isolated low-risk enemies.
That ammunition economy could make the Evictor feel rewarding for careful players while punishing careless firing.
A Flexible New Primary
Overall, the GL-15 Evictor could be less about replacing existing weapons and more about changing the way a complete loadout is organized. Its combination of explosive damage, structural utility, and a primary-slot position gives it a distinctive place in the arsenal.
For players who want to expand their options without giving up a dedicated anti-tank support weapon, the Evictor could be worth watching. If you are also comparing different ways to manage your resources, checking options such as cheap Helldivers 2 Super Credits can help you prepare for the new Warbond and other content without changing the way you build your actual combat loadout.
Helldivers 2 Evictor Guide: U4N Looks at Its Best Roles
JackWalker
- Nazione: 6
