MMOEXP: Arc Raiders sends you on plenty of item retrieval
Inviato: 26/02/2026, 8:56
ARC Raiders sends you on plenty of item retrieval or combat missions, but one quest you'll encounter simply asks you to raise a flag for the sake of unity. If you've obtained the A Symbol of Unification quest, you'll be ready to get out there and start bringing folks together. Luckily, we're here to help you do so with an explanation of where to find the flag and how to raise it. Let's dive in.
Where you're headed to complete A Symbol of Unification isn't typically overflowing with other players but the areas you may need to pass through such as the Wreckage and Scrap Yard could be, as they're common spots for mushroom farming. With this in mind, just be sure to prepare accordingly. You don't need to extract to complete this quest, so it's not a bad idea to toss on a free loadout while working on it just in case you run into trouble and don't make it back to Speranza alive.
When you're ready to bring a bit of unity to the raiders, you'll need to load into the Dam Battlegrounds map and head to the Formical Outpost at the bottom right of the map. This outpost is up on a tall hill, so be prepared for a bit of a trek. When you reach the Formical Outpost, head inside and look for a medical bed on your right. You'll see a backpack you can interact with. This will spawn the Raider Flag, so pick it up to add it to your inventory.
With the Raider Flag acquired, you're halfway done with the quest. The only thing left to do is raise the flag, which can be done in the outpost. Just head to the back of the outpost and check the flagpole outside. Interact with it to raise the flag and complete the quest.
With the A Symbol of Unification complete, you're now free to finish looting before you extract, or simply head quickly to ARC Raiders the nearest extraction point, which is likely the Red Lakes Balcony lift to the northeast. Be careful here, though, as it's a common spot for extraction campers to wait for raiders to come by.
Buy ARC Raiders Items,trade safe buy ARC Raiders Materials at MMOEXP with a cheap price,fast delivery and the best service. Don't hesitate,order ARC Raiders Coins now!
Details: https://www.mmoexp.com/Arc-raiders/Items.html
