Queue into Black Ops 7 Season 2 and you'll clock it fast: the EGRT-17 is in nearly every killcam. If you're warming up in a CoD BO7 Bot Lobby or jumping straight into ranked, the story's the same. The gun just works. It fires quick, it hits hard enough, and it doesn't punish you for taking mid-range fights. The only real issue is that the stock recoil can bounce when you try to stay on target through a full spray.
Start with the parts that calm it down
Most players build the EGRT-17 the same way because the basics matter more than flashy tweaks. The Redwell Shade-X Suppressor is usually the first pick: it keeps you quiet and helps the rifle feel less twitchy when you're holding lanes. After that, the 19.1″ XR-Compulsion Barrel is the big upgrade. You feel the bullet velocity right away, especially on maps where people head-glitch at distance and your shots need to land now, not a beat later. If you're the type who tracks instead of flicks, those two attachments alone make the gun feel way more "point and print."
Underbarrel and grip choices that actually show up in fights
This is where the EGRT-17 stops being "good" and starts feeling unfair. The Sentry Pro Handstop or the Bowen Sentry Foregrip both cut the side-to-side wobble that ruins long bursts. It's not just about recoil stats; it's about keeping your reticle from drifting off shoulders when someone strafe-peeks. Pair that with a rear grip like the Nanite or the EAM Capacitor and the rifle settles down even more. You can stay on the same target longer, and it's easier to swap targets without over-correcting. That's what wins those messy two-on-one moments near an objective.
Fire mods, wildcard, and the way people really run it
There's a split on the fire mod slot. Buffer Springs is the safe play: snappier feel, faster follow-up shots, and it suits aggressive pushes. The MFS Heated Echo Rounds are the fun (and sometimes toxic) option. Ricochets up to three times can steal kills when somebody slides behind a box thinking they're safe. But yeah, it kicks more, so you've gotta be honest about your recoil control. To fit everything, Gunfighter is basically mandatory. Then round out the class with Ghost, Fast Hands, and Cold-Blooded so you're not lit up by UAVs or AI streaks, and keep a Stim Shot ready for quick resets between gunfights—if you want to buy CoD BO7 Bot Lobby for practice and unlock progress, this same setup still translates cleanly into real lobbies.RSVSR is where Black Ops 7 players come for what's hot right now and the kind of tips you can actually feel in-game. If you're eyeing Season 2's meta, the EGRT‑17 is a monster—fast fire rate, clean damage, and it gets downright nasty with a Shade‑X Suppressor, XR‑Compulsion Barrel, and a steadying handstop to calm that jumpy recoil. Want the full build, plus smart class picks like Gunfighter, Stim, Semtex, and stealth perks?
RSVSR Where the EGRT 17 Meta Build Shines in Black Ops 7 S2
Hartmann846
- Nazione: 3
