Some side quests in Diablo IV don't care how hard you hit—they care whether you're paying attention. If you're cruising through the Dry Steppes hunting events, hoarding Diablo 4 gold, and ticking off map icons, "Keeping the Old Traditions" can feel like it's messing with you on purpose. It starts quietly in the Untamed Scarps, where a book called "The Lonely Offering" has been tossed on the ground like someone gave up mid-prayer. You read it, get a riddle, and that's it. No fight, no big arrow that solves it for you. Just a line that sounds poetic until you realise it's basically asking you to respond.
Finding the clue that actually matters
The riddle goes on about something timeworn and "colorful kin," but the word that matters is the simplest one: "Yes." A lot of players miss that because we've been trained to look for an interact prompt, not a conversation. You'll probably do what I did the first time—run toward the marker and start clicking around like there's a hidden switch. There isn't. This quest is one of those little moments where Diablo IV expects you to use the tools you normally ignore, and it's oddly satisfying once it clicks.
Where the statue is and what to do there
The marker leads into the Valley of the Strayed, to a worn statue/monolith set into the cliff like it's been there forever. Stand right in front of it. Not off to the side, not ten steps back—right up close. Then open your Emote Wheel. Here's the catch: the "Yes" emote usually isn't slotted by default. So you have to customise the wheel, find "Yes" in your emote list, and place it on an open slot. After that, do the emote while facing the statue. No extra steps. The quest doesn't want flair; it wants the answer.
Why it's worth doing and a quick gear note
When you perform the "Yes" emote, a hidden chest pops up nearby. The loot won't always be a jaw-dropper, but it's still a nice bundle—gear, gold, sometimes elixirs, and a clean bit of Dry Steppes Renown. That's the real value if you're trying to push region progress for potion capacity and those extra skill points. It's also a good reminder to check your emote setup now and then. Diablo IV sprinkles a few of these "say the right thing" interactions around, and they're easy to miss if your wheel's barebones.
Optional help for the grind
If you're the type who likes knocking out side content fast, it helps to keep your resources topped up so you're not stopping every ten minutes to scrap, sell, and restock. As a professional like buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy u4gm Diablo 4 gold for a better experience while you focus on Renown routes, elixir uptime, and cleaning up the Dry Steppes without the usual downtime.
Welcome to U4GM, where Diablo 4 tips feel practical, not preachy. If you're roaming the Dry Steppes, don't skip Keeping the Old Traditions: grab "The Lonely Offering," find the weathered statue, then hit the "Yes" emote to pop a hidden chest for XP, renown, and loot. Need a quicker gold boost for upgrades while you explore? Check https://www.u4gm.com/diablo-4/gold and get back to solving secrets your way.
