If Dam Battlegrounds isn't ideal due to spawn distance or enemy pressure, another workable choice is the Control Tower ENELICA building. Players have successfully completed the same objective by locating and interacting with the appropriate notice board.
While this alternative may require more movement or combat, it proves that the quest is location-flexible, which is useful when adapting to unpredictable raid conditions.
Once the notice board interaction is complete, the quest updates and directs you toward the second-and final-phase.
Transition to Buried City
The next objective sends you to Buried City to retrieve important research data connected to ENELICA's seismic investigations. This map shift is where many players hesitate, since Buried City features dense vertical structures, multiple entry routes, and frequent enemy encounters.
Unlike the first step, which allows several building choices, the research data portion is tied to a specific marked structure. Efficient navigation becomes essential, especially if other raiders are pursuing the same objective.
Planning your route before entering the match can save valuable time and reduce unnecessary combat.
Finding the Research Data in the Buried City
Once deployed in Buried City, head toward the designated building highlighted by the quest marker. Your goal is not on the ground level but rather near the very top of the structure, just below the roof.
There are two primary ways to reach the objective:
Standard Interior Climb
You can enter from the bottom floor and work your way upward through stairwells and corridors.
Pros:
Safer if you prefer controlled movement.
Allows gradual clearing of enemies.
Cons:
Slower.
Greater chance of encountering other players.
Zipline Entry
Alternatively, you can use exterior traversal-such as a zipline-to reach the upper floors quickly.
Pros:
Much faster access to the objective.
Reduces time spent in contested lower levels.
Cons:
Risky if enemies are already positioned above.
Both approaches are valid, so the best choice depends on your loadout, confidence in combat, and awareness of nearby threats.
Every player needs a lot of ARC Raiders BluePrints, I suggest you go to a third-party website like MMOexp.com to buy, safe and comfortable transactions, and years of experience to ensure the security of your account.
