How to Farm Heavy Gun Parts Blueprint in ARC Raiders U4N
ParkerBlair
Moto: Blair
motoclub: Blair
Nazione: 12
Messaggio da ParkerBlair » oggi, 8:59
The Heavy Gun Parts Blueprint is an important crafting unlock for players who want a steady way to produce Heavy Gun Parts through Workshop Refiner 2. Rather than searching for finished materials every time, securing the blueprint gives you permanent access to the recipe. If your current goal is expanding your stock of ARC Raiders Items, knowing where to spend your time can make the hunt much less frustrating.
Start with the main loot sources
The blueprint is a random world drop, so players should not expect a fixed chest to provide it every time. Instead, focus on the container types that have been repeatedly associated with blueprint drops.
Raider Containers and Caches are among the most useful places to start. Uncovered Caches are especially important because community reports have pointed to them as a valuable source of blueprints.
Military and weapon containers should also be included in your route. Ammo cases, Weapon cases, and Grenade tubes can all be worth checking. Since these containers are connected with military supplies, they are sensible targets when your main objective is a weapon-related crafting blueprint.
Why Uncovered Caches matter
Uncovered Caches are useful because they can turn a normal exploration route into a more focused farming run. Instead of opening every container you see, you can learn several cache locations and move between them.
This approach also makes your results easier to measure. If you repeatedly visit a known group of caches, you can quickly tell whether the route feels efficient and adjust it when necessary.
Remember that random loot can be streaky. A good route improves your opportunities, but it does not remove RNG from the process.
Farm Buried City when possible
Buried City is one of the locations players have highlighted for Uncovered Cache farming. Community reports suggest that the Heavy Gun Parts Blueprint may appear more often there than during similar attempts in Spaceport.
The difference should not be treated as a guaranteed drop rate. You may still complete multiple raids without finding anything useful. The main advantage is that Buried City can give dedicated blueprint hunters a strong environment for repeatedly checking relevant caches.
Once you learn the area, try to keep your route simple and avoid unnecessary fights.
Add Night Raids to your options
Night Raids can be useful when you want to search locked areas. Players have reported good loot opportunities in rooms such as Blue Gate breach rooms.
These areas naturally come with more risk, so your decision should depend on how comfortable you are with the route. The goal is still efficient farming, not winning every possible fight.
If you can enter, loot, and leave safely, the extra opportunity may be worthwhile. If the route constantly puts you in difficult combat, a safer daytime cache route could produce better results over several raids.
Look for EM Storm opportunities
The Dam is another location worth remembering when an EM Storm is active. A community-reported strategy involves using a grappling hook to reach a water tower on the southern side near the electronic substation and checking the containers there.
This is not a guaranteed blueprint location, but it gives players another option when the conditions are right. Keep it in your mental checklist rather than waiting specifically for the weather to change.
Protect the blueprint
The most important rule is simple: use the Safe Pocket immediately after finding the blueprint.
Blueprints can be extremely frustrating to lose because the value comes from permanently unlocking a crafting recipe. If you keep the item in your normal inventory while searching for additional loot, one bad encounter can wipe out the entire achievement.
Once it is secure, you can decide whether to extract immediately or continue the raid. In most cases, securing the rare item should be the priority.
Use the base as a fallback
If your luck remains poor, Celeste provides a practical temporary solution. Players can use Seeds to purchase finished Heavy Gun Parts at the base.
This does not give you the permanent crafting recipe, but it means you can still make progress toward weapon production while continuing the blueprint hunt. There is no need to let a missing blueprint completely stop your crafting plans.
Keep your farming routine flexible
The best approach is to rotate between strong opportunities instead of relying on one route forever. Prioritize Buried City and Uncovered Caches, check relevant military containers, and take advantage of Night Raids or EM Storm opportunities when they fit your run.
A flexible strategy keeps farming from becoming too repetitive and helps you make better use of each raid. If you also want more options for managing your broader resources, cheap ARC Coins can be considered as part of your overall progression planning.
This guide covers the best ways to farm the Heavy Gun Parts Blueprint in ARC Raiders, including Raider Containers, Uncovered Caches, military containers, Buried City, Night Raids, and EM Storm opportunities at Dam. Remember to secure rare blueprints in your Safe Pocket and use Celeste as a temporary crafting solution. For more gaming resources and trading services, visit u4n.com, a reliable game trading website for players looking to manage their in-game needs more conveniently.
